VariCAD 2023-1.0- Nov 30, 2022 (English + Português)
Opening a second VariCAD Window.
While working with VariCAD, you can open a second window (second instance of the application). This gives you a possibility to check other 2D/3D files, measure values and mainly, copying objects into a clip-board and pasting them into the working area. In the second VariCAD window, you can edit objects before you copy them into a clip-board. However, you cannot save VariCAD files directly. Apart from using a clip-board (Ctrl + C, Ctrl + V), you can save selected objects into a new file.
Unlike the full version of VariCAD, the second instance cannot run batch printing or batch files conversion. On the other side, you can check assembly structures, single solid structures, BOM and even contours (profiles) in sketching planes. In all such situations, it is possible to copy data into a full version of VariCAD.
This feature is especially convenient, if you run VariCAD on 2 monitors.
Working with Solid Tree Structure, Deactivating Solid Elements.
Working with a solid tree has been changed. Now, the behavior is identical in all cases. The feature can be invoked, if you right-click a solid and select from a pop-up menu, or if you click an corresponding icon in tool-bar and then select a solid, or click a solid and then a corresponding icon in a tool-bar.
Working with solid’s tree structure, you can deactivate/activate elements. If an element (like a hole, filet, added rib…) is deactivated, it remains in the structure. The solid is rebuilt without it. Obviously, deactivated elements can be later activated and solid is rebuilt again with them. This allows you to create variable shapes of mechanical parts.
If elements are inactive, you can select them only in the tree scheme. While browsing objects in the list, these inactive objects are highlighted the same way as active objects. Their displayed shape corresponds with the state when they were deactivated.
There are limited possibilities to change the inactive elements. It may be convenient in situations, when you change a location or a shape of other solid parts and the inactive elements would not fit into a new position, when they are activated.
Display of Preview of Open Documents.
If you have open multiple documents, you can change them from a pull-down menu or from a command. In the first case, you browse menu items, in the second case, a list of documents. While browsing documents, a preview of them is displayed. If the number of open documents is higher, you may not be sure what exactly each particular document contains.
This feature may cause a greater load to graphics, so it can be disabled. If VariCAD detects hardware which may be insufficient, the feature is turned off automatically. It is possible to turn it on/off explicitly in command “cfg”, in section “Working with Multiple Documents”.
Using a Clip-board in 3D.
Behavior of Copy and Paste of 3D objects has multiple options now. It can be set in command “cfg”, in section 3D. While inserted from clip-board, solids are located into a previous position or into coordinates center, according to settings. Moreover, solids from clip-board can keep their original transformation. This allows you to assemble 3D solids exactly according to original model. Until recently, this option was the only available for inserting from 3D clip-board.
Measure Distances, Angles….
All measurements are available from a corresponding tool-bar. Now, you can run them also from a pop-up menu, if you right-click an empty area. This works both in 3D and 2D.
Abrir uma segunda janela do VariCAD.
Ao trabalhar com o VariCAD, é agora possível abrir uma segunda janela (segunda instância da aplicação). Isto fornece a possibilidade de verificar outros ficheiros 2D/3D, medir valores e principalmente, copiar objetos para o clipboard e colá-los na área de trabalho. Na segunda janela do VariCAD, é possível editar os objetos antes de os copiar para o clipboard. Contudo, não é possível guardar os ficheiros do VariCAD diretamente. Além de os usar através do clipboard (Ctrl + C, Ctrl + V), é possível guardar os objetos selecionados para um ficheiro novo.
Ao contrário da versão completa do VariCAD, esta segunda janela não permite trabalhar com a impressão e conversão de ficheiros em modo batch. Por outro lado, podemos verificar as estruturas de montagem, as estruturas sólidas simples, Listas de Materiais e até contornos (perfis) nos planos de esboço. Em todas essas situações, é possível copiar os dados para a versão completa do VariCAD.
Esta funcionalidade é especialmente conveniente, se tivermos o VariCAD a trabalhar com 2 monitores.
Trabalhar com a Estrutura em Árvore, Desativar Elementos Sólidos.
O trabalho com a árvore de sólidos, foi alterado. Agora, o comportamento é idêntico em todos os casos. Esta funcionalidade pode ser invocada, fazendo clique com o botão direito do rato num sólido e selecionar a partir de um menu de pop-up, ou se clicarmos num ícone da barra de ferramentas pretendida e de seguida for selecionado um sólido, ou ainda, fazendo clique num sólido e depois no ícone correspondente, numa barra de ferramentas.
Ao trabalhar com a estrutura de sólidos em árvore, podemos ativar/desativar elementos. Se um elemento (como um furo, um boleado ou um ribe…) estiver desativado, este vai permanecer na estrutura. O sólido vai ser reconstruído sem este elemento. Obviamente, os elementos desativados, podem ser ativados mais tarde e o sólido vai ser reconstruído de novo, tendo em consideração estes elementos. Isto permite a criação de várias formas de peças mecânicas.
Se alguns elementos estiverem inativos, é possível a sua seleção, mas apenas no esquema em árvore. Ao navegar pelos objetos na lista, estes que estejam inativos, são realçados do mesmo modo que os elementos ativos. A sua forma visualizada, corresponde ao estado de quando foram desativados.
Existem possibilidades limitadas para a alteração de elementos inativos. Pode ser conveniente em algumas situações, ao alterar a localização ou a forma de outras peças sólidas, em que os elementos inativos não se ajustem numa nova posição, quando são ativados.
Visualização de uma Pré-Visualização de Documentos Abertos.
Se existirem vários documentos abertos, é possível alterá-los a partir de um menu deslizante na parte superior do VariCAD, ou a partir de um comando. No primeiro caso, podemos navegar pelos itens do menu, no segundo caso, uma lista de documentos. Ao navegar pelos documentos, é mostrada uma pré-visualização dos mesmos. Se o número de documentos abertos for grande, podemos não ter uma certeza absoluta sobre o conteúdo exato de cada documento.
Esta funcionalidade pode necessitar de um maior número de recursos gráficos, por isso pode ser desativada. Se o VariCAD detetar hardware insuficiente, esta funcionalidade é desligada automaticamente. É possível fazer On/Off explicitamente no comando “cfg”, na secção “Trabalhar com Vários Documentos”.
Usar o Clipboard no 3D.
O comportamento do Copiar e Colar nos objetos 3D, possui agora várias opções. Este comportamento pode ser definido no comando “cfg”, na secção 3D. Ao inserir a partir do clipboard, os sólidos vão ser localizados na posição anterior ou para o centro de coordenadas, de acordo com as definições. Mais, os sólidos a partir do clipboard podem manter a sua transformação original. Isto permite a montagem dos sólidos 3D, exatamente de acordo com o modelo original. Até recentemente, esta opção era a única disponível, para a inserção a partir do clipboard 3D.
Medição de Distâncias, Ângulos….
A partir desta versão, todas as medições estão disponíveis a partir de uma barra de ferramentas correspondente. Agora estes também estão presentes a partir de um menu de pop-up, se for feito um clique com o botão direito do rato, numa área vazia. Este procedimento funciona em ambos, 2D e 3D.
