AXISVM X7r3 - New Features in Existing modules (Part 1)
Determining the required amount of reinforcement based on allowed crack width
In SLS combinations, the program calculates the required amounts of reinforcements based on the set limits for crack widths. It allows for flexible control over where and in which direction crack widths are limited.
Simultaneous consideration of applied and calculated reinforcements in nonlinear analysis (optional)
When this option is enabled, during nonlinear analysis, the greater value between the calculated and applied reinforcement will be taken into account.
Utilization of result components for the actual reinforcement
The utilization of the actual reinforcement is determined based on the capacity curve of the cross-section.
RC2
Documentation of the applied shear reinforcement used in the design calculation
In the Actual Beam Reinforcement tab, the checking of the user-defined stirrups is documented in the design calculation.
Optional consideration of torsion in the design of RC columns
In the design of reinforced concrete columns, the check for torsion can be switched on/off.
Enhanced shear check of reinforced concrete columns
The biaxial shear check can be disabled in the verification of the RC columns. In addition to the linear summation, a parabolic relationship can also be used for verification.
RC3
Punching analysis results can be displayed as new result components in the model window as well
Punching check considering connecting ribs
The punching check is also available for columns with connecting ribs.
Punching check of column reinforced wall ends/corners
The punching check of wall ends/corners can be performed even if a column is connected to the wall end/corners.
RC4
Additional options for the design of footings
The range of verifications taken into account in the design of footings has been extended. The footings can be designed based on a specified set of verifications.
Verification of footings against uplift
If an upward force acts on the footing, the program checks whether the self-weight of the footing counterbalances the corresponding external force.
Extension of stress-strain analysis to virtual beams
RC8
Custom fire curves for reinforced concrete elements
It is suitable for modeling designer-specified fire curves, as well as calculated through fire simulations or gas temperatures measured fire curves.
Modified hydrocarbon fire curve for reinforced concrete elements
New fire curve for fire design of reinforced concrete elements.
RC8-B
New exposure type when specifying fire load
The sides of the cross-section exposed to the fire can be adjusted as required (for example, when positioned against a wall or in a corner).
SD1
More accurate lateral torsional buckling moment values
The program considers the semi-rigid end joint stiffness of the connected beams when determining the lateral support stiffness.
SD8
Modified hydrocarbon fire curve for steel elements
New fire curve for fire design of steel elements.
