combining two solid objects
I am fairly new to Keycreator. I am currently working on a project. I designed two different solid drawing. At first the design was going to be a two piece. Now we decided to make it a one piece. So object A is .040 inch smaller than object B. Is there an easy way to combine the two objects without having to redraw everything? The gap is between solid gold to solid blue.
Hi, very nice to have you on board. Regarding your question, what you want is to join the 2 solids in one single solid?
Can you send the file so that we check it?
