EZCAM 2026 - What´s new in EZCAM 2026
1. Industry-Leading 3D Toolpaths
3D Roughing
• Auto side lead-in/out from stock boundary enables the tool to automatically lead in and out from the edge of the stock material.
• If helical plunging is not feasible due to a narrow area, the system automatically switches to Zig-zag within the limits and continues safely.
• Minimize Jumps option replaces Z-rapid retracts with optimized safe-Z lifts.
3D Re-Roughing
• Independent control over re-roughing parameters allows a separate set of plunge settings, machining allowances, finish tolerances, and boundary definitions.
• Accurate rest material computation for all tool types ensures precise detection of uncut material regardless of tool type.
New 3D Finishing Strategies
• Parallel, Radial, Morphcut, Curve Projection
• Supports undercut tools such as T-slot and lollipop cutters.
• Supports selection of Check Surfaces and specification of minimum and maximum Surface Angle parameters.
• Smooth automatic ramp in/out
• Variable Step mode for consistent scallop height
Spiral Finish
• Automatically transitions to elliptical spirals for wide areas
• Users can define both the cutting direction and the starting point.
• Allows the addition of dedicated finish passes within spiral operations
• Variable Step maintains scallop tolerance while optimizing X-Y step length
Pencil Milling Enhancements
• Adds support for multiple pencilcut passes
• Also supports constant-Z passes by specifying the Z step parameter
2. Next-Gen Wizard Interface
Redesigned UI with modern visuals and always-visible data panels.
Faster Programming and Simulation
Right-Side Command Panel
Seamless Workstep Navigation
Automatic Tool Diameter
In-Place Renaming
A new right-click feature allows for easy renaming of worksteps directly in the list.
3. Curveless System Improvements
Curveless now supports: pocketing, contouring, chamfering, wrapping, 4th-axis, drilling, threading.
Wrapping with Open-End Pockets supported in EZ-MILL and EZ-TURN
Pocketing/Contouring with Bosses Combine Regions supports embedded features
SmartClick Enhancements
- Selects flat faces at same Z height; ignores blind hole ends
- Supports wrapping via face selection at same diameter
- Draft/taper angles automatically populated
- Automatically set Z-surf and Z-depth
- Avoids faces with negative surface normal
- Allows curveless indexing without UCS using first selected surface
4. Workflow, Automation & Integration Enhancements
Enhanced “World on Surface” Command
Endpoint-Based Direction Control: EZ-WEB Tools
UI & Automation
Geometry Copy/Paste works across layers and EZ-CAM modulesSpreadsheet command can sync Tool Data across all worksteps using same tool numberAlibre Enhancements
Feature data from design tree transferredSolidWorks Plug-in
5. EZ-EDM: Redesigned Icons
All command icons have been redesigned in a larger 32 x 32 size.
Video:
