AxisVM x7 - NEW FEATURES IN BIM
IFC
Additional import options
New options are available for importing an IFC model: Overwrite, Add, Update.
Export of special domains
The IFC export option is available for ribbed, hollow core, composite ribbed, and trapezoidal steel deck slab domains.
Revit-AXISVM
Support of Revit 2023
The supported file versions have been extended with Revit 2023.
AXISVM transfers the model data using the API interface of Revit (Revit 2019 or a newer version is required).
Rhino/Grasshopper
New interface for V6.0 Rhino/Grasshopper
New features and options available in GrasshopperToAxisVM V6.0:
► component for definition of parametric cross-sections
► XLAM domain, references, and component to define spring characteristics
► node-to-node and line-to-line link elements
► additional load options (seismic, snow, wind, fluid, support displacement…)
► launching AxisVM analysis from Grasshopper (linear and nonlinear static, vibration, buckling, and seismic analysis)
► creating steel members
► creating timber members
► optimizing the cross-section of steel and timber members
► certain result components can be imported back into Grasshopper
Revit/Dynamo
New interface for V3.0 Revit/Dynamo
The components available in the new interface support all AXISVM element and load types.
